Concealed soft close hinge for corner door
Discussion in 'Kitchen Fitters' Talk' started by Michael Lord, May 25, 2021.
  1. Michael Lord
    Michael Lord New Member
    I am replacing sprung cabinet hinges with soft close.
    I have managed the normal ones fine using Nickel Soft-Close Clip-On Concealed Hinges 116mm. However the corner doors need a different hinge as the non recessed fixing is screwed to a surface at 180 degrees angle to the door instead of 90.
    It is not at all clear which hinges I need to buy to do this, the specifications bizarrely do not mention how wide they open. Can someone help?
    Mike
