Concealed toilet
Discussion in 'Plumbers' Talk' started by tore81, May 10, 2019.
  1. tore81
    tore81 Well-Known Member
    Hi all looking to install a concealed toilet.
    Inlet valve is already in place and looking get rid of exsisting and just have a shelf for maintenance etc.
    The issue I have is the soil pipe is there a way round it.
    Would a flexi work.
  2. KIAB
    KIAB Well-Known Member
  3. KIAB
    First question should have been, where is the location of the soil pipe,through wall, in floor,stack pipe?
  4. tore81
    Soil pipe is coming through the floor. That looks like it would work.
    I have cast iron and it's been sealed with some sort of putty cement.
    Would this be easy to remove and fit one of these
  5. KIAB
    Post a photo.:)
    Can usually clean off the gunk,or even cut pipe flush with floor, if has a collar.
    Would have thought pipe in floor was clay.
    Crowsfoot likes this.
  6. Pollowick
    Pollowick Well-Known Member
    Just keep a bucket under the bed - that will be concealed!
    KIAB likes this.
  7. tore81
    Yes sorry it looks clay. How would I cut clay thanks for reply
  8. KIAB
    Usually a 9" grinder, but I've done it with 4.5" grinder,section at a time,where access is tight, stuff a rag down pipe to stop any bits falling down pipe,but make sur rag isn't snagged by grinder.
