Hi,
I’m in the process of opening a kitchen/dining area. The house is on a concrete foundation and id like to level and insulate the floor.
I’ve taken levels spots around the floor to find the low/high spots, 10mm difference from l/h. My current thought process and sequence is to lay the XPS insulation on a flex adhesive directly on the concrete floor. Then lay the underfloor heating and then pour the levelling compound laying it thicker in the areas that are lower. The floor area is 16.5sqm, only 6sqm will have the under floor heating.
The floor will be LVT.
Any advice or recommendations is welcomed.
