Concrete patio cost roughly ?
Discussion in 'Builders' Talk' started by Ben48, Sep 12, 2018.
  1. Ben48
    Ben48 Member
    Hi I am considering getting quotes for an concrete patio for my entire garden (don't need no soil or grass etc) its roughly
    8 metres(26foot) wide by 20 metres (65foot)
    How much roughly does it cost for concrete patio of that size (with sand/mot sub base etc) ?
  2. sospan
    sospan Well-Known Member
    Seems a complete waste to concrete a garden that size
  3. Isitreally
    Isitreally Well-Known Member
    Maybe they want to build a "Park & Ride" :)
  4. sospan
    Could put a few vehicles on there - but a fraction too small for a tennis court
  5. Ben48
    Ben48 Member
    Very low maintenance is the plan :)
    Any idea of rough cost please
  6. chippie244
    chippie244 Well-Known Member
    I could be wrong but I think you have to put something water permeable down.
  7. wiggy
    wiggy Well-Known Member
    £50 m2
    Ben48 likes this.
  8. sospan
    Due to the size you would probably need building control and probably planning due to the surface water issues
  9. Isitreally
    Far to cheap.
    Ben48 likes this.
  10. DIY womble
    DIY womble Well-Known Member
    £49.99/ m2
    Ben48 likes this.
  11. wiggy
    Enlighten me?
  12. What you going to do with all the rainwater?!
    Ben48 likes this.
  13. PhilSo
    PhilSo Active Member
    It's only 10 mm deep.
    :D
    Ben48 likes this.
  14. Isitreally
    Double what you said.
  15. wiggy
    Well thats a start in answering the OPs question
  16. rogerk101
    rogerk101 Well-Known Member
    That's one sure way to trash the eventual resale value of the property!
    However much it might suit your (quirky) needs, you will eliminate 99.9% of the potential buyers, because fewer than 0.1% of them would even consider the property with a fully concreted garden.
    Ben48 likes this.
  17. Ben48
    Ben48 Member
    Not sure if my math's is right so at £50 m2 around 8K and £99 m2 looking at 15K+ for concrete patio ?
    I used the b&Q patio calculator and cheapest bradstone patio slabs and it still came to around 2K-2.5K to cover 8metre by 20metre garden, so is concrete just more expensive then patio slabs ?
  18. Isitreally
    You have 160M2 to cover, the cost of the slabs is minor part of the overall cost.
    Even using the cheapest slabs you could buy it would cost you around 12 grand mark.
    Ben48 likes this.
  19. rogerk101
    Have you factored in the cost of labour to lay the concrete slabs PLUS the hardcore base PLUS the finer substrate on top of the hardcore based on which to lay the slabs?
    Ben48 likes this.
  20. Isitreally
    Plus the digging out and removal of any spoil, this in its self on an area this size would run into thousands.
    Ben48 likes this.
