Condensation on thermal break windows
Discussion in 'Builders' Talk' started by DIY_Has123, Mar 21, 2021.
  1. DIY_Has123
    DIY_Has123 Active Member
    So had a new aluminium window put in couple years ago...ALUK brand and I'm sure it has thermal break.
    But I've found heavy condensation on window frames as I recently had room plastered. Obviously have kept window open but can't really through night because of security.
    I found contradictory information online as some sources say condensation does not happen on thermal break windows.
    Is this true or can condensation still occur?
  2. Astramax
    Astramax Super Member
    Aluminium sweats plus after plastering what do you expect with excess moisture in the air it condensates on the coldest area ie the window.
