Got up this morning and the house is very cold considering the heating is on full time now.Red light on ,no hot water or heat.Boiler was serviced in Nov' so i rang the guy but he cant get here untill 6 ish tonight so i got the service manual out to see if there is any thing a chippie can check.The first thing on the fault list is,is the condensate discharge pipe clear?went outside and lo,its frozen solid!so i pulled it off and a * load of water ran out from inside the wall part of the pipe...Turned the boiler on and all is well,must be colder than i thought.Never seen this before ,maybe a bigger pipe needed?. [Edited by: admin]
Fitero, a couple of points. Yes, you need a larger pipe - use waste pipe, or lag the existing. Two, the condensate is highly acidic so there's no point me telling you this as you are now dead. You were a good cove.
Yes i was,i miss me allready and i'm sorry to bore the other whatsis name[not really,i could give s* but i doubt it].
Is it really true that she sucks? And does she still have her own teeth or can she take them out first?
