Connecting chrome bottle trap to 40mm pipe
Discussion in 'Plumbers' Talk' started by azizrasul, Sep 10, 2019.
  1. azizrasul
    azizrasul Member
    I have a chrome bottle trap, with a horitzontal 35mm pipe, which I want to connect to a verticaal 40mm white plastic waste pipe coming up from the ground. How do I do this?
  2. KIAB
    KIAB Super Member
  3. azizrasul
    azizrasul Member
    Many thanks.
  4. DIYDave.
    DIYDave. Screwfix Select
    Or can use solvent weld pipe and fittings and reducers
    The compression fittings are rather ‘chunky’, not a problem if not on show but if exposed, can slim things down somewhat with solvent weld
    Just another option (sorry no links) o_O
  5. Hans_25
    Hans_25 Screwfix Select
    Solvent weld is great as long as the pipes are an exact fit/size, may well need a compression fitting for the 35mm pipe and compression fitting is v useful if you ever need to take the thing out. Assume the bottle trap will be compression.
  6. KIAB
    KIAB Super Member
    Thinking the same.:)
  7. Heat
    Heat Screwfix Select
    If waste pipe is for push fit, then obviously you would have to use only push fit or compression.
    But if it is solvent weld pipe you also have the option of push fit universal fittings which have a larger diameter and heavier seals.
  8. KIAB
    KIAB Super Member
    Chrome pipe might be metal or plastic chrome finish pipe.
  9. DIYDave.
    He’s also gonna have to use a 90 bend as talking about horizontal pipe from waste, joining into vertical pipe from floor
    The trap will be compression at sink end and onto waste pipe so forever removable for future cleaning / blockages
    Also then gives access to pipe for above issues
    Just saying that solv weld is a neater / space saving way forward but yes, depends what type pipe coming outta floor at present
    As we know, compression here is much more forgiving with slightly different pipe sizes / brands / systems / but ...... boy is it bulky ;)
