Connecting toilet pan
Discussion in 'Plumbers' Talk' started by osca, Jul 23, 2012.
  1. osca
    osca New Member
    stack?
    Would it be too restrictive?
    Thank you.
  2. Crowsfoot
    Crowsfoot Screwfix Select
    I gotta say that I don't personally fit those ? pan connectors and always work out something else to fit.
    Like you say they are too restrictive one good dump with them fitted and it's out with the plunger !
  3. clive holland
    clive holland New Member
  4. osca
    osca New Member
    Thank you both for your replies. This is what I expected. I'm glad I asked.
    Thank you, Geoff.
  5. ThreadJacker
    ThreadJacker Active Member
    I must admit I * like King Kong through my swan neck connector at home and its never blocked, what does block are those god awfull 82mm internal fin pan connectors. They're the jobbie trappers.
    Message was edited by: Screwfix Moderator
