Hi All I have seen a thread before. However I believe my requirement may vary. I have a large garage. I want to have two led PIR flood lights installed. Basically I want them both to come on when either one is triggered. I will require a small one, to one side as this overlooks the neighbours garden. Both are different wattages, so can they be connected? Is there any particular make/model yourselves would recommend?
Okay would there be any issues with the loading? Anything you would recommend within the SF range? I have always used Steniel PIRs in the past with JCC Toughfloods. Thanks Ind.
You will need separate pirs as you need to common the switched supply. As for loading you'll need to look at ampage of lights and switching load of pir.
