Hi everyone, I have a lean to L shaped conny which wraps round the house. (bought the house already like this) It is insulated and plastered inside (my doing) but still has the polycarb roof. We are getting a leak when it rains sometimes. Its either the wind blowing it under the flashing? or when the rains in the right direction it gets in via the bricks which i believe need repointing. Problem i have is there is zero access to this brickwork unless i crawl on top which i dont fancy doing. Is there anything else I could try to maybe seal the bricks/mortar joints to see if it makes a difference something i could do without the need to be up close? Any ideas welcome that dont involve ripping the plaster and insulation down or replacing the roof
Have a looksee if the polycarbonate sheets will slide down if you remove the stops at the bottom. Then access from inside off stepladder or short ladder.
I cant access from inside. Should have been more clear, it is the roof i had insulated and plastered. I will have a look for movement from outside
