Conservatory roof glazing bars
Discussion in 'Plumbers' Talk' started by bathroom boy, Jun 26, 2010.
  1. bathroom boy
    bathroom boy New Member
    I need to do some work above my pitched apex conservatory roof, upvc and usual polycarbonate glazing sheets, it also has an pitched roof extension next to it making scaffolding extremly difficult and also expensive, I am now thinking of removing the roof panels to do the work, thing is how do I get the glazing bars off?
  2. Lucky
    Lucky New Member
    Hey BB
    They are usually a T Section , you should be able to prise off the T Section from above , only problem is if it`s old Kit they get pretty britle and break too easy , The T Section is sometimes serrated - ribbed on the part that fixes into the Base , I`d try with a wide bolster 1st to spread the stress
    Lucky
