Convert a Single socket fuse box to a power socket
Discussion in 'Electricians' Talk' started by FadBurty, Jan 14, 2020.
  1. FadBurty
    FadBurty Member
    Hi,
    I have a fusebox for an old alarm system. Since the alarm box has been changed those Single fuse box is no longer in use. I'm not sure, but can this be converted in to a plug socket?
  2. terrymac
    terrymac Screwfix Select
    What circuit is this "single fuse box"on?
    I assume you are referring to a fused connection unit. ( Same size as a single socket outlet ).
