Converting surface mounted to in Wall plugs
Discussion in 'Electricians' Talk' started by Movieman334, Dec 24, 2021.
  1. Movieman334
    Movieman334 Member
    Hi guys did anybody have any recommendations on how to proceed with converting mounted plug boxes to in Wall ones
    This is what thhey are currently like
  2. terrymac
    terrymac Screwfix Select
    Just be prepared to do the making good ,plastering / painting etc, around each one . If the walls are brick/ block it's much harder than if the walls are stud ( plasterboard on timber). And take great care not to damage the cables when breaking out the space for the back box's.
    Movieman334 likes this.
  3. Movieman334
    Movieman334 Member
  4. Movieman334
    Movieman334 Member
    This is a current back box set in the house , note idiot tenant broke this one
  5. terrymac
    Fitting the sockets is the easy bit !
  6. terrymac
    If the walls tiled ,I would just fit another surface mounted box ( unless you intend to re tile anyway)
  7. Movieman334
    Movieman334 Member
    Nah they are
    nah they are all wall paper ,
  8. Comlec
    Comlec Screwfix Select
    I would blame the idiot who fitted a surface mount socket so close to floor level rather than the tennant.
    candoabitofmoststuff likes this.
  9. Mark Griffiths
    Mark Griffiths Active Member
    If it's a solid wall, then the easiest way is to drill a series of holes in the wall at the same depth as the backbox (Prob 25mm) and then chip out the block. The difficulty with this is making sure that you don't damage the cables and the cable entry to be in the correct place for the knockout hole.
    If it's a plasterboard wall, then it's fairly simple and just a case of cutting the slot in the plaster and avoiding the joists. However it's unlikely to be plasterboard as if it was then you wouldn't be likely to have surface boxes.
    Most important thing to keep in mind is to protect the cables and make sure that you turn the power off before starting any work.
    It's not a hard job, just be aware that you'll probably need to tidy up & decorate around each of the sockets after the job is done. You might be lucky and be able to get away with just fitting some socket surrounds and not needing to decorate.
  10. Sparkielev
    Sparkielev Screwfix Select
    If they are flat plate then you will need 35mm back boxes
  11. FlyByNight
    FlyByNight Screwfix Select
    Buy an Armeg box sinking kit ...
    It is not a clean task - better off waiting and doing each room as you redecorate.
  12. Truckcab79
    Truckcab79 Screwfix Select
    My whole house has these. Built in the 1950’s and no idea why they were done that way. Thought they’d really bug me but as I’ve decorated each room I’ve painted each box in the same emulsion to match the wall and used decent quality brushed stainless face plates. Don’t even notice them and a lot less work. Only ones I’ll sink in are the kitchen ones as they do look really obvious sat on the surface of the tiles.
  13. Movieman334
    Movieman334 Member
    very true, idiot electrician and idiot tenant, both idiots. any way I'm going to un idiot these 2 and this situation :) lol
  14. Movieman334
    Movieman334 Member
    this looks briliiant but bloody expensive
  15. CGN
    CGN Screwfix Select
    You won’t have any joy on brick, ok on soft block.
    Sparkielev likes this.
  16. FlyByNight
    Some bricks they are fine, engineering bricks, no chance.
    If doing a full redecorate, then a small angle grinder plus SDS drill and wide chisel.
    CGN likes this.
  17. Movieman334
    Movieman334 Member
    Thanks guys. Shah damn I don't have a sds drill . Hmm I don't wanna. Buy one if only need for one day .
    What do.you guys think about the following
    1. Draw the outline of the box
    2. Drill little holes eg 4 x 3 like.this video
    3. Then use something like.this scutch tool to.chisel out the box shape
    https://www.toolstation.com/draper-scutch-chisel/p18718?
    Note I've got 6 or 7 in total
  18. Truckcab79
    It’ll do the job but for £40 all in just buy a cheap angle grinder and a diamond cutting disc. Don’t underestimate the amount of dust. Few seconds in and you’ll be barely able to see what you’re doing. Dust goes everywhere. Have a vacuum to catch as much as you can. Horrible way to do it but it works.
    The Titan wall chasing tool is decent. About £100 and genuinely good dust extraction. Make a much quicker and cleaner job of it but at a price.
  19. Movieman334
    Movieman334 Member
    Ohhhhh I know all about dust . It's ridiculous. I think you're right better to have vaccine cleaner on hand.
    I have an angle grinder , this guys done a video using angle grinder
  20. Sparkielev
    If you are unsure about doing this, then buy trunking socket boxes they don't shatter and are better than the cheap bakerlite boxes
