Hi all,
I’ve decided to convert a light switch in my house from a standard single light switch to a single dimmer switch. I’ve watched a few YouTube videos and done some research but I’m very confused with the wiring situation. I currently have 2 overhead lights connected to one switch. The current layout is:
-yellow wire into com
-red and blue wire into 1 way
-three red wires into 2 way
The new dimmer switch I’ve bought has the following terminals:
-L2
-Common
-L1
How should I convert these over? I’ve tried putting 3 red wires from 2 way and common wire into common terminal and other blue and red into L1 as per instructions, however this keeps the current constant, regardless of whether the light switch is on or off. I’ve since turned the fuse off again, as I’m worried this is a risk. I’ve never changed a light switch before and am relatively new to DIY electricals. Any help greatly appreciated!
TIA
-L2
-Common
-L1
TIA
