Cooker hood help
Discussion in 'Kitchen Fitters' Talk' started by Marc Berry, Nov 28, 2021.
  1. Marc Berry
    Marc Berry Member
    Mainly i have a question but then any other advise welcome .
    The question is that i bought a ducting kit. 5 inch. It comes with flexible ducting, the wire type with the metal covering. It also comes with the external vent
    I thought I'd test fit the ducting to the vent but it seems too tight to go on. Even though they're bought together
    Am I missing something? Is therea knack to it maybe?
  2. Marc Berry
    Marc Berry Member
    I just got a reply from the seller who simply said i may need to 'work' the ducting some more to get it to fit the spigot
    Doesn't help much.
  3. Marc Berry
    Marc Berry Member
    Anyone?
  4. woodbutcherbower
    woodbutcherbower Well-Known Member
    Best advice is to ditch the metal ducting (I hate it, it’s too rigid) and grab some standard plastic flexi. Fix to the duct outlet using the large jubilee clip supplied.
    Top tip - many people make the mistake of using a 127mm core drill as they think 125mm flexi will go through the hole. It won’t. You’ll need a 132mm core. Get a decent one such as a Marcrist red.
    Marc Berry likes this.
  5. Marc Berry
    Marc Berry Member
    Cheers mate.
    Yeah might be best.
    I messaged the install diameter of the hose and the outside. The outside is just over 125mm and the inside just under but it's simply too tight
    I'll have another mess tonight
  6. Notnowvicar
    Notnowvicar Active Member
    If its any help I find the brick external vent type easier to fit, just drill out the mortar line and if the metal is tight fight warming it up and give it a few tugs normally works...if not go round with the tin snips/ scissors to feather the edge and aluminium tape it.
  7. Marc Berry
    Marc Berry Member
    Cheers mate.
    I've now ordered plastic ducting to see if that helps and it should come today. I'll have a mess later with it all
  8. Marc Berry
    Marc Berry Member
    I've just got the plastic tube and it goes on easy. Great suggestion.
    Hopefully an easy job now
  9. woodbutcherbower
    Good stuff. Glad you got fixed up.
