Cooker socket above cooker
Discussion in 'Kitchen Fitters' Talk' started by AJones88, Apr 7, 2021.
  1. AJones88
    AJones88 New Member
    I inherited my dad's house 2 yrs ago and I am finally going to replace the gas cooker. I have noticed there is an old cooker socket in the middle behind the gas cooker, I will be replacing the cooker with a built in grill below the hobs not on top.
    Will this socket be a problem and would the gas engineer still be able to install the new cooker?
    Any advice is much appreciated.
    Thanks
    Aaron
  2. polybear
    polybear Member
    It's most definitely against current leccy installation regulations - I suspect some gas fitters may refuse. Ask over on the Electricians Board about the full regs, as to where it should be. Or fit a leccy cooker....
  3. Dream_Home
    Dream_Home Active Member
    The first thing to say on the matter is that there is no specific regulation in BS7671 requiring a cooker switch to be installed at all. Appendix H of the On-Site Guide says that a control switch should be supplied and located within two metres of the cooker and not directly above it.
    However if you are having a new kitchen etc then it is considered best practise to position it at least 300mm for the cooker
  4. DaveF
    DaveF Active Member
    30cm.
    That's a bit of a muddle of outlets, switches and pipes. It very definitely needs to be improved.
    I would get rid of that gas pipe if it is no longer being used, to tidy the area. Then you need to move everything electrically. I would get a combined cooker switch with 13A outlet to replace the cooker switch you have and the separate socket. I suspect the switch is for a fan? That should be mover further away. 30cm for all electrical stuff. Also with a modern electric cooker you may need a heavier power cable, your electrician will tell you that. But yes, it needs a little work.
