Hi all Just a bit of advice. A friend of mine is quite financially hard up has been awarded a new freestanding electric cooker via a charity. Her current electric cooker has the cooker switch on the wall about 30cm above the hob. The cooker is wired into a plate lower down. The charity that are delivering said they won’t install the cooker of the switch is on the wall behind as it doesn’t meet current regs. As the switch is not effectively being touched and only the cooker is being wired in then surely this shouldn’t be an issue. I understand that current regs would not allow a new installation for this but I thought current installations unless a change is being made do not count
Typical of people who don't understand the regs. No problem at all. Although it is convenient and advisable to have access to an isolating switch it's not always possible in an existing installation.
Cheers for this. I don’t know the regs but just repeated what they said so presume it was in the regs. I also thought the regs only existed with new installations or changes to existing ones and simply wiring an oven up to existing outlet would come under it Will need to be there I think when they deliver and install is there any reference to this that I could show them
A cooker isolator above a cooking appliance is wholly unacceptable. It is nonsense to suggest that it is acceptable to have the switch above a hob. It isn't. It is wrong and poses a hazard.
Hi I know it’s not practical but is it against regs could you point me in the direction where it states so. I need to know if it’s in regs or if it states anywhere that this is ok. As said I’m only trying to help a friend
Unacceptable to whom? What hazard? And as the Op asks, let’s have the regs that prohibit such an arrangement. Oh and if it is non-compliant how would it be coded on an EICR?
@Comlec only if you have a fire blanket, dry powder and CO2 fire extinguisher to hand lol. Kind regards
Although an old publication it is unacceptable to the NICEIC. https://www.voltimum.co.uk/sites/ww...007043012988137r_switches_connections_156.pdf
I could suggest that numerous Regulations could be relevant: 134.1.1 134.1.5 131.3.1 528.3.1 528.3.3 I am pleased to state that the ETCI Wiring Rules are much more explicit on this: "555.2 Cooking appliances "555.2.1 In domestic and similar installations, an isolating device for a cooking appliance shall not be mounted either directly above or behind the appliance." It is horrendous practice and clearly poses a hazard to the user. Anyone who has promoted this practice should be banned from describing themselves as Electricians forever.
I have done a full risk assessment of this situation and find the following. I would rather risk being banned from describing myself as an electrician forever than let a poor woman go without a cooker. But that's just me acting as a caring and compassionate human being rather than a pompous pedantic jobsworth's. @OllyUK if your friend is within 50 miles from me I'll come round and fit it free.
No it isn't. It's proof that you are an arrogant danger to the community. The OP was correctly advised that this is not an acceptable setup. FULL STOP. END OF STORY.
It cant be right for the cooker isolator switch to be in that position. Not arguing, but no way tbqh. I always adhere to the recommended NIC 300mm minimum from the side of the gas/electric appliance - at a push would go to say 270mm, but have never had to do this.
