Copper Jointing Glue!!
Discussion in 'Plumbers' Talk' started by Bonedry, Feb 10, 2008.
  1. Bonedry
    Bonedry New Member
  2. ukrobj
    ukrobj New Member
    hi Bonedry,
    I've seen this "just for copper" glue, took it to the local collage (I live opposite the head of engineering dept, we put it too the test and took it to 10 bar at 70 degrees for an hour, held with no problems!
    Not sure if like to use it in a customers house though!
  3. Water Systems
    Water Systems New Member
    hi Bonedry,
    problems!
    though!
    I would like it pressurised and at 110C for 8 hours and see how it goes. Reports I have read say it is very good and passed for gas as well. Have you seen the price? Expensive to go a whole system. However a DIYer could justify it. It would be fine for the odd awkward joint.
  4. tooltarticus
    tooltarticus New Member
    Have heard of it, but know nothing of it.( bonedry, your link is to a page regarding thermal stores- wtf?) Sounds very gimmicky to me. Under what conditions will it denature? what sort of longevity are you talking? Do I need to keep a clear space in the diary in 2018 because these glued joints are all going to start blowing?
  5. Water Systems
  6. ukrobj
    ukrobj New Member
  7. tooltarticus
    Thanks chaps, very interesting. Don't think Solder manufacturers need break out in a cold sweat just yet though
  8. MOONSHINE
    MOONSHINE New Member
    It's been shown on QVC many times
  9. graceland
    graceland New Member
    tried testing it at our college once, absolute c-rap. just pulled apart after it set
  10. Water Systems
    Are you sure you did it right and waited long enough. This stuff has been extensively tested in the UK ad the USA.
  11. Bonedry
    Bonedry New Member
    Thanks for your comments.
    I have heard mixed reports and as you all would probably agree the jury is out so its a no go until its tested more.
    How long before we get the calls from DIY jobs that are now blowing at the joints?
    Apologies over the link mix up.
  12. Jimthecob
    Jimthecob New Member
    Copper jointing glue...thats flux and solder isnt it?
  13. Captain Leaky
    Captain Leaky New Member
    I saw some on sale in PTS the other day. I asked if they ever sell it, apparently not - no-one wants to ask for it and be laughed out of town. :)
  14. graceland
    yes tested long enough, we set it and then went to lunch for an hour. just broke apart with a bit of pressure. cant remember the actual brand
  15. Water Systems
    its tested more.
    It has been <u>extensively</u> tested and been around for about 10 years. Don't take notice of one poster who no doubt screwed it up.
    Testing authorities in the USA and UK can't both be wrong.
  16. Water Systems
    They are the sort who fit tanks and cylinders all the time.
  17. Water Systems
    I have never tested under lab conditions, but used it to glue a 2mm elbow and after 20 minutes it was rock hard. That was Just 4 Copper.
  18. doitall
    doitall New Member
    We were using Loctite glue for potable stainless steel pipes in food processing plant 30 years ago.
  19. Water Systems
    Yep. Gluing pipes is not new. This Just 4 Copper has been around a while and well tested. I only know of one fitter who uses Just 4 Copper. He uses it for awkward joints and joints where a blowlamp would ruin decorations - as it is quite expensive. He has never had a failure. His view is that if the price came down he would use it for whole systems. He says using it on surface work makes the job look real neat. He also said the pipe has to be fully round and very clean - well a bit like any joint really.
  20. doitall
    doitall New Member
    Very clean and de-greased ;)
