Hi everyone, this is my first post on here. Can anyone help me? I need a 32A TYPE 1 MCB to fit a Crabtree SB6000 consumer unit. I have tried my local wholesalers and they only stock the 610 type which is listed as a replacement for pre 1992 MCB's. These have the bottom screw set to the right. I need the type 1 which has the bottom screw over to the left. Does anyone know how I could contact Fatman, as he posted that he had some last month? Cheers.
http://www.rbstaronline.co.uk/acatalog/Crabtree_Starbreaker_range__old_type.html And welcome to the forum
Hi Pengu, The one you posted the link to is the 610 type that Edmundsons & Neweys stock. The picture clearly shows quite a large strip of plastic to the left of the lower screw. My type 1 has only got 2mm on the left, but 5mm on the right. The MCB has a grey switch. It says in green (top to bottom) TYPE1 32A Crabtree. On the side it readss Crabtree SB6000 Category M6 BS3871. It also has 61151 over to the right of this. Cheers.
Like http://www.thefusecompany.com/fuse.php/cPath/69/productsid/392?sid=6994fcae7b560df6e6098d24b8677d32 Or http://www.thefusecompany.com/fuse.php/cPath/69/productsid/392?sid=9eec321030bd92a15b386ca6b8056fc3
Hi Pengu, The one you posted the link to is the 610 type that Edmundsons & Neweys stock. The picture clearly shows quite a large strip of plastic to the left of the lower screw. My type 1 has only got 2mm on the left, but 5mm on the right. The MCB has a grey switch. It says in green (top to bottom) TYPE1 32A Crabtree. On the side it readss Crabtree SB6000 Category M6 BS3871. It also has 61151 over to the right of this. Cheers. As its green and has 61151 almost certain its a type 61 the successor to the 610.
Like http://www.thefusecompany.com/fuse.php/cPath/69/produc ts_id/392?sid=6994fcae7b560df6e6098d24b8677d32 Or http://www.thefusecompany.com/fuse.php/cPath/69/produc ts_id/392?sid=9eec321030bd92a15b386ca6b8056fc3 Excellent website - loads of info and piccies. Anyone got any more of these gems? Steve
