Crack in conservatory concrete floor
Discussion in 'Builders' Talk' started by Ian Morrison, Aug 11, 2018.
  1. Ian Morrison
    Ian Morrison New Member
    Hi,
    Had a conservatory installed recently, over the past few weeks we have noticed 2 cracks appearing in the concrete floor by the door.
    Any ideas what could have caused these cracks, is it just due to the recent heat or is it something I should be concerned about?
    Any suggestions who I should call to take a look at if is an issue?
    Thanks
    Ian
  2. stevie22
    stevie22 Active Member
    How recently? First call should be to whoever built it.
  3. Ian Morrison
    Hi,
    The conservatory was built on the base that already existed from a previous conservatory. The base was originally built 15-20 years ago
  4. blarblarblarblar
    blarblarblarblar Active Member
    Wouldn’t have any issues just yet. Leave it for a while and see if it gets bigger.
  5. sospan
    sospan Well-Known Member
    If there is more weight with the new conservatory, you can easily get some cracks as the slab readjusts to the new weight - plus we have had a really dry summer and this won't help at all if you have clay undersoil
