Crack
Discussion in 'Builders' Talk' started by mark atkin, Jun 30, 2020.
  1. mark atkin
    mark atkin New Member
    anyone know how to permantely resolve it only from halfway to soffit.
  2. Joe the Plumber
    If you were a 1970s Spanish property developer, you'd just say: "Eees, how you say - 'expansion joint', yes please".
    Joke out of the way, is it just the render that's cracked, or does it go into the wall below it too? From your photo, it looks like it's the wall that's cracked, but it's difficult to see.
    Has it just appeared, or has it been there a while?
    And is there any sign of it inside the house?
  3. mark atkin
    It goes through the wall seems the concrete blocks have split in half from bottom of render to top. No cracks inside house or bottom of brick work. Its been there a while as someone tried to cover it up with sealant.
  4. Abrickie
    Abrickie Super Member
    Before you fix it, you need to establish the cause ;)
    Joe the Plumber likes this.
  5. Frutbunn
    Frutbunn Member
    This is quite typical of an expansion crack, how long is this elevation?
  6. stevie22
    stevie22 Screwfix Select
    I agree with Abrickie: this is a strange one and needs the cause rectified ahead of remedials. Suggest you get an experienced SE to look at this
  7. David Hatim
    David Hatim Active Member
    Sorry, came to the wrong page, looked at the title and thought you were selling
