creaky carpet
Discussion in 'Carpenters' Talk' started by cold_in_winter, Nov 14, 2006.
  1. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Back to the creaky carpet saga, try these
    http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid
    =IZ211VLEUFBOYCSTHZOCFEY?id=15310&ts=24993 stuff em
    in, no problems. cheap too ;)
    Do you need a pilot hole for these ?
    (Oh, and before you say it, DD, I am joking)
    Mr. HandyAndy - really
  2. Mr. Handyandy
    h my God, goldenboy. You really ARE jealous.
    You weigh up the pros and cons, they make your decision.
    I too, do this.
    I do not bodge.
    I will take twice as long to do a job, if I get better results.
    I am in fact, a bit of a perfectionist, mainly at my own cost.
    I cannot do a job to a bad standard.
    It is not in my nature.
    I will improvise, which I see as a skill, to be able to use a material or a method in a different way, to get over a problem.
    As I said before, if I thinks it's wrong, I won't do it.
    If I think it will work(although not standard) I WILL do it and achieve the desired result.
    I fail to see the wrong in that.
    If you need any more tips, just ask. I don't hold a grudge, pleb. :O
  3. fooman
    fooman New Member
    According to regulations, there should be no
    pipes or
    [/b]wires within 2 inches of the top of the
    floorboards.
    And I know, you can't guarantee it, but if you are
    worried, use a detector.
    Mr HandyAndy - Really
    Have to go to the hospital now, my sides have split
    :^O
    hes suggestions on the Electrical forum are even more of a howler :^O
  4. fooman
    fooman New Member
    pipes or
    floorboards.
    :^O
  5. Mr. Handyandy
    pipes or
    floorboards.
    are
    split
    :^O
    of a howler :^O
    See, I have a remedy for everything.
    Sides split with laughter ?
    Go for a long run, until you get 'stitch'.
    :):D
    Oh, and FOOLman, take a look at yourself.
  6. Mr Mike
    Mr Mike New Member
    Just in, just checked & yep my winkie's still bigger than all of yours put together. Have a nice weekend, :)
  7. dirtydeeds
    dirtydeeds New Member
    mr mike it is a VERY important subject :)
