Crown Solo still the choice?
Discussion in 'Painters' Talk' started by imcalledal, Dec 8, 2009.
  1. flonk
    flonk New Member
    if you want a job done properly...
    dont use cronw solo
  2. Lloydy
    Lloydy New Member
    I'm going to use solo for the first time this weekend. whats the best way to use it? keep reading if applied properly. any secrets tips?
  3. Guttercat
    Guttercat New Member
    You tell us what you're intending on applying it over, and I/we will tell you, how to or how not to apply it.
  4. Lloydy
    Lloydy New Member
    Hi Guttercat,
    Previously glossed skirting and doors, also a new cheap b&q white internal door.
  5. Guttercat
    Sugar soap and 400 wet and dry at the same time. Wipe down with a damp clean sponge. Lightly touch up any bare patches and straight on with the "Solo" using a good clean brush.
    Your new door: Just a very light rub down with dry 400 (don't take the primer off) ...dust off and apply your liquid gold. ;)
    Crank the heating up
  6. Lloydy
    Lloydy New Member
    Cheers Guttercat.
    Do you aply plenty on without spreading it much or thin ?
  7. potty painter
    potty painter New Member
    Lloydy.
    Dont overload your brush, you will be amazed just how easy Solo is to apply. It goes on like cream, a sheer pleasure to use. And truly is liquid gold!!!!
    Let us know how you get on.
    Potty.
  8. freshtec
    freshtec New Member
    im not a massive fan of solo and would not pick it over a good quailty standard oil based paint. its a good pick if your in to DIY or dont paint a great deal as its easy to work with.
  9. proby
    proby Active Member
    Never used crown solo so im open minded. Was just wondering if its that creamy to work with whats your thoughts on adding owatrol oil to help it spread.
  10. Guttercat
    Easy to work with, doesn't make it bad............. it makes it good.  I paint a great deal  cos I'm a pro'  and I use it loads.
    No need to add anything to it because it's great anyway.
    By the way.............Crown ~Solo self undercoating gloss,  is not  thixotropic.
  11. Boolay
    Boolay Member
    Completely agree with Guttercat & Potty. Use it loads.
    Lovely stuff
  12. Puma
    Puma Guest
    I am completely confused by this thread, yes it does cover well but when I used it on a cheap to let property I found that IT'S GREY, it was so grey I found myself repainting stuff because I thought it needed another coat.
    Is Dulux once also GREY
  13. Puma
    Puma Guest
    Thats the Solo Gloss. Is the satin the same?
  14. imcalledal
    imcalledal Member
    How strange. I cant say i have ever found it to be grey! Was that just the one tin you tried?
  15. Puma
    Puma Guest
    No I went through 10 liters on the property. It went on white and then faded back within a couple of days.
