M
Mr. Handyandy
Guest
Nice one, Jules - the "what's the point - he ain't listening" 'argument'.
You know, the one that sums up those with 'faith'. And nothing else. Like you.
In my post above, I hope I showed that I am not dismissing magnet effect completely out of hand, as it is a genuine physical property, so could quite possibly have a physical effect. (Tho' it almost certainly does not).
Homoeopathy, however, now that's a beaut. Complete cuckoo land stuff. Fairies, unicorns and 'magic water'. The world of crystals and pebbles and chants and prayers.
I'm now going to test you, Jules, because you've asked for it...
You say I won't change my mind? Here's the truth, sunshine - I will. If I'm given credible, impartial evidence.
Do you know what homoeopathic medicine actually is?
Read - and weep: it works on the principle that a substance that causes the symptoms of a disease in healthy people will cure similar symptoms in sick people.
For example, if an ill person has, say, coughing fits as a symptom of their disease, then you should give them a substance that would cause similar coughing to happen in a healthy person.If they have, ooh, diarrhoea, then you give them something that would cause diarrhoea in a 'well' person. If the sick person has heart palpations, you give them something that would cause palpitations in a healthy person.
Read that paragraph again. And again if needed.
This was one guy's idea around 200 years ago.
If that in itself isn't loony enough, the guy who started this - Hahnemann - found, not surprisingly that if you gave the ill person this substance in undiluted form, it made them more ill (this guy's a genius). So, he started to dilute them in distilled water. Again and again. To the point where there are usually no molecules remaining of the original substance. So he's left with - water.
But, but, but, each time you dilute the substance, you have to strike the container on a firm surface. Then - oh I really can't be ar***...
It really doesn't matter
Homoeopathy has been shown again and again and again to be as daft as it clearly is. But, of course, there will always be 'believers'. Those with irrational faith.
Enjoy.
Isn't that exactly what todays innoculations are? To protect you from ilnesses, you are given the illness(or an injection containing the virus) to help you build antibodies to protect you in the future.
Mr. HandyAndy - Really
