Hi, Hoping to extend a radial circuit wired in [I think!] 7.036 t/e but wasn't sure what the rating of it was. I think its broadly the same as 4mm. It looks like this 70's house was wired in radials and at some point someone had stuffed three 7.036's into one 32a mcb to create a little space. No spare ways, got to provide for 2KW underfloor heating! Cheers, 14th
be carefull here you might need to downgrade breaker due to inadequate cpc. then you could have nuisance tripping have you laid flooring?
Nope, made the mistake of taking socket off adjacent to new conservatory, seeing two pairs and assuming ring main!!Tested for continuity and sweet FA on anything.Asuming radials at present, testing am tommorrow. Whats the issue with CPC size? I can replace with a 16a breaker no probs, kitchen and extension are on separate rings[much more recent stuff]. Cheers 14th
7.036 can have a breaker up to 31a so as soon as you alter that ctt your responsible well liable no spare ways little options here maybe an add on?
Hi Lamps, Cheers for help, may move another cicuit at DB to create one extra for 7035 and derate to 16a. Cheers, 14th
dont touch ctt m8. if it starts tripping your phone will start ringing, advise them and price it up the freebies always get you
7/.029 has a csa of 3.0mm and an individual strand diameter of 0.74mm (measure with a vernier caliper to confirm size). It is rated at 31A on an MCB or cartridge fuse. 7/.036 has a csa of 4.6mm and an individual strand diameter of 0.91mm (measure with a vernier caliper to confirm size). It is rated at 41A on an MCB or cartridge fuse. CPCs could be either 1/.044 =1.0mm csa & 1.12mm strand diameter, 3/.029 =1.3mm csa or 3/.036 =2.0mm csa. Do the adiabatic to confirm cpc size adequacy for MCB ratings once you know the cpc size. Without performing the calcs myself just now, IIRC these 3 strand cpcs are good for 32 and 40A MCBs respectively. This info comes from a scan I have of the relevant ratings table from the 1966 issue of the wiring regs (14th edition I think).
Ah, sorry thought you meant RCD! New heating will be 1.8kw, say 8-9 amps. No other real load on same circuits. 14th
PCelectrics, Must be 1044 as it is single strand, unless it is 7029...But it looks too chunky for that. I don't possess a vernier! 14th
How do you identify imperial cables for the purpose of verifying their suitability in a circuit if you cannot measure them to identify them? Get these into your next order, only 15 quid: http://www.screwfix.com/search.do;jsessionid=FOC5Q3RKQKXLKCSTHZPCFEY?_dyncharset=UTF-8&fhsearch=36839
14th Edition 7/036" did have a cpc of 3/029" same size as 7/029" 1/044 was only used as the cpc in 3/029" my source of reference is the 14th edition light blue cover dated 1966 was ammended to 14th edition metric cables in 1970 orange cover
