Curtail Rail
Discussion in 'Just Talk' started by Henry Smith, Apr 2, 2024.
  1. Henry Smith
    Henry Smith Member
    Hi all,
    It’s my first time installing a curtain rail into concrete. If I bought a pole which had a bracket in the middle, would I literally just have to measure the width of the windows and half it to find the centre point?
    it’s my first time drilling into concrete, as I’ve just got the correct drill so would just like to make sure I’d be doing it correctly. I have attached a photo of where the curtains would be going for reference.
  2. Mark DM
    Mark DM Screwfix Select
    If its a fixed centre bracket I would offer the pole up and mark the fixing holes. Ofter it's adjustable and then clamped in position with a grub screw or similar in which case just measure and mark the center position .
    If you are drilling with a sds drill then it should drill without issues. If a regular hammer drill, go slow to avoid burning out the drill bit.
