Cut through hedge trimmer mains cable
Discussion in 'Electricians' Talk' started by fred812, Jul 16, 2021.
  1. fred812
    fred812 Active Member
    Hi, cut through the mains cable on a 450 watt mains hedge trimmer. What should i use to repair it? From SF if possible.
    Thanks.
  2. Tony Goddard
    Tony Goddard Screwfix Select
    Muzungu likes this.
  3. Muzungu
    Muzungu Screwfix Select
  4. FlyByNight
    FlyByNight Well-Known Member
    Integral cable or on with a plug/socket? And which end ... trimmer or plug?
  5. Bazza
    Bazza Screwfix Select
    Err, where the cable has been chopped?
  6. FlyByNight
    Yes, if close to the mains plug - just a new plug, half way along, possibly an inline connector or in close to te trimmer then either a complete new cable or re-terminate in te unit.
  7. fred812
    Thanks for the replies. The cut is about half way along near as dammit. 10m cable. Thinking that 2 pin plug connector is the fix. How safe is the live side of the plug?
  8. FlyByNight
    You put the SOCKET side of the pair on the end connected to the mains plug and teh PLUG on the remaining end from teh trimmer. They are perfecty safe - unless a baby puts their finger into the socket. You do need to confirm your hedge trimmer is just L&N 2-core, if not and there is an earth, you will need teh three way version of the connector assembly.
  9. Bazza
    The live side of the connector must be the half with the holes (ie socket) thus is connected to the power half of the cable.
    the bit of cable that goes to the trimmer MUST go to the plug half- that’s the bit with the sticking out pins.
    this is the sfx part u need
  10. fred812
    Thanks all. Yes, I understand that the socket side must go to the plug and the pin side goes to the trimmer. Would it be acceptable to wrap it in insulation or duct tape to stop it coming apart?
  11. Tilt
    Tilt Active Member
    They don't usually come apart that easily.
    You will not need to tape them together fred.
  12. The Happy Builder
    I have a 110 volt electric Stihl chainsaw, I fitted one of these rather then a 110 volt plug and trailing socket so it would come apart if the cable was snagged to stop it pulling the saw back onto me, there’s been a few times I’m glad I did.
  13. FraserD
    FraserD Member
    I've done this three times, is it just me that has used a cable connector and silicone tape?
    It is on an RCD though..
  14. Bazza
    Time to buy yourself a rechargeable battery one then!
    FraserD likes this.
  15. FraserD
    FraserD Member
    I'll have to soon.. Not many shrubs left in reach. :rolleyes:
  16. FlyByNight
    FraserD likes this.
  17. FraserD
    FraserD Member
  18. FlyByNight
    Be careful or you could cut your tongue off
    FraserD likes this.
  19. Teki
    Teki Screwfix Select
    As mentioned above, one solution would be to replace the entire length of cable if you are comfortable opening up the hedge trimmer. Local garden tool repair shops can also do this for you.
    You can also fit this close to the cable from the hedge trimmer (15cm) and wire yourself a new mains plug cable with the orange socket at the other end. That way, if you cut through it again you are only replacing the mains cable.
    Alternatively, if you want to just repair what you have but a more secure solution instead of a plug and socket arrangement, then opt for one of these inline cable joints:
    https://www.toolstation.com/ip68-in-line-cable-joint/p65284
