Hey guys Can anyone recomend from experience any manual cutter to cut 20mm porcelain outdoor tiles please? These are 600x600 My tiler tried on his Rubi cutter and it would cut them but they would split uneven. I have a load of cuts so prefer manual if I can.
20mm!! wouldn’t fancy that tbf. What you could try, and it’s worked for me before, is to score them, place a batten underneath the score, foot on one side and a confident stamp with your foot on the other. Try one and report back
A friend just used a wet cutter on 10mm tiles and the cuts were taking so long. is that how they work or did he have a bad cutter or blade? I’m not expecting to cut in 30 seconds but I don’t want each cut taking 15 minutes. typically how long would good (hire) wet cutter take to do a 600mm cut?
I wouldn't even attempt to cut 20mm porcelain on a manual cutter. The success rate would be way below 50% I reckon. I just use an angle grinder with a decent blade, cuts through in no time.
