Cutting cast iron
Discussion in 'Screwfix Live' started by Doug Ward, Oct 17, 2019.
  1. Doug Ward
    Doug Ward New Member
    Hi all. I'm looking to cut a cast iron fire surround.what kind of disc would you recommend???
  2. Wayners
    Wayners Screwfix Select
    Metal cutting disc. One of those thin ones. Ware all the gear though as sparks will fly
  3. Tony Goddard
    Tony Goddard Screwfix Select
    I find the thin 1mm discs give the best finish quickly, but you will go through a few.
    If you are doing it inside have a fire extinguisher handy, also protect any windows from the sparks, they fuse to glass and can't be got off. Cast cuts well and produces loads of sparks and black dust!!
    Plumb Loco and KIAB like this.
  4. KIAB
    KIAB Super Member
    Norton metal cutting & the slitting disc's from competitor last well & cut very cleanly.
