Cutting doors to fit carpet
Discussion in 'Carpenters' Talk' started by upsticks, Feb 12, 2005.
  1. big all
    big all Screwfix Select
    if they are slotted screws take a flat bladed screwdriver
    place the blade at an angle at one end of the slot tap the handle with a hammer driving the blade along the slot to clean it out
    then place the blade firmly in the slot and tap firmly with the hammer to locate the blade and help loosen the screw
    if its a star screw make shure you are using the correct bit[9 times out of 10 its a pozi no2]tap the head firmly
    big all
  2. big all
    I've never used a biscuit jointer, but from what I've
    seen of the blades, aren't they a bit rip-saw-like ?
    I haven't seen biscuit blades with more than about 6
    teeth. Wouldn 't these rip the door apart ?
    Handyandy - really
    your right about the lack of teeth h a
    but because you only go half way through you dont get breakout on the other side
    the only place it may happen is on the lock end but if you slow the cut down as it is about to appear your ok
    i say dont knock what you havent tried
    and i am a southern softy from just below the southern lowland of scotland
    big all
  3. archie
    archie New Member
    mate just hire a door trimmer from any hire shop - no need to take doors off - job done!
  4. panlid
    panlid New Member
    big all, you said finish off with a handsaw... what kind of doors are these? i bet it looks **** and you have gone down in my estimation. please tell me this is a wind up
  5. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    but because you only go half way through you dont get breakout on the other side...
    It would be breakout on the near side, wouldn't it ?
    I know. I'm nitpicking now, but.....
    Handyandy - really
  6. panlid
    panlid New Member
    BIG ALL an anagram of I BLAGG
  7. Mr. Handyandy
    SIDNEY, an anagram of Mickey Mouse(DISNEY)
    Handyandy - really
  8. panlid
    panlid New Member
    lolol...
    handyandy an anagram of...errrr
    andyandy
    h
  9. big all
    heelloo again sid
    the bicie jointer wont usualy do the inch or so nearest to the hinge edge
    so you just need to clean that bit up
    ok h a your right about the breakout being on the front edge but as its with the grain till the end of the cut
    but of course when you arris the edge to clean it up you have got to be very very unlucky for any thing to show
    and of coure its a method of last resort and nearer to a bodge than a propper job
    big all
  10. big all
    another point wouldnt like to use on hollow doors as they may be ply or the block as you say is likely to be non existant
    if you are worried about rough edges have you ever seen a rough edge with a bickie joiner going with the grain
    big all
  11. panlid
    panlid New Member
    thanks big all for your reply and confesion to it being nearer a bodge;-)
    carpet fitters normally take doors off if it wont fit anyway so its errelevent really. quick plane and some new screws on.:)
  12. upsticks
    upsticks Member
    Archie I found the door trimmer at HHS so thanks for that, useful as a last resort if the screws won't budge.
    Thanks also for all your other suggestions.
    Upsticks.
  13. panlid
    panlid New Member
    come again were always here to help ;)
  14. bodget&scarpers
    bodget&scarpers New Member
    yes do *** again, we thank u 4 flying with sfd, and hope u have enjoyed ur time with us, and hope u will fly with sfd very soon,and we wish u a safe journey home, thank you
  15. panlid
    panlid New Member
    bogit if you were new on here youd think we were all aload of b****s. which were not of course ;)
    [Edited by: Forum Moderator]
  16. Hoppy100
    Hoppy100 New Member
  17. bodget&scarpers
    thats wat i mentioned on the 4th post,but at £410 :(
    i wood shop a round.
  18. panlid
    panlid New Member
    **** me just take the bloody door of and plane...
  19. Dewy
    Dewy New Member
    You will probably see that the door trimming saw has a 100mm blade the same as biscuit jointers.
  20. handyman.
    handyman. New Member
    38 posts on trimming a door! I as a scumbag handyman get these c**y jobs a lot and I only ever take the door off.
    O no.......I agree with SID again :)
