yes dewy but i bet its got more teeth. dont tell me your a lazy b***d too [Edited by: Forum Moderator]
so wats the best way 2 get the screws out of the flapped bits of metal,some times 3 on a door? only joking,lets put this baby 2 bed
I have just finished a job today where I had to rent a door trimmer!!! It was a old cottage and the doors were on with t hinges fixed to front facing x 7. The lady had the hole place painted and didnt want to 'break' the paint. It also had lots of coats on it (no screw heads seen) I must admit it.............its very good. If I had £250 spare I would get one. But, I will now give it as an option to customers. £30 rental plus time to go get it!.
hi handy did it get right in to the inner edge, or do you have to faf about a bit , reason being never used one before always whip door off .
BTB, its a great bit of tooling. The blade is on a slide, so you just set the depth slightly more than door thickness. You then just run it along the door. keep you eye on it as you reach the hinged end. All floors were bare, so to get height I sat machine on a piece or underlay and carpet. The blade is set a further 3mm above this height. Easy. Get one if you need one, its the dogs. Just suprised theres not a cheap version.....yet.
A lady friend had moved into a new house and had carpets fitted which made the door impossible to move. As a favour I removed the door and started cutting 1/4" or so off the bottom. The blasted door had the bottom rail nailed on. A 'quick, easy job' ended taking hours and blunted my tools. Never again.....
i have a flooring company and was so sick of people needing doors trimmed i spent £500 on two door trimmers and two power planers for the carpet fitters to keep in the vans. I thought as i had made such an investment it would be reasonable to try to recover some of my money so i decided to charge £10 to cut the first door and £7 for each extra door. Will the customers pay? will they b***x! they expect me to do it for free. [Edited by: admin4]
yeah ok, tell u what seeing as your giving me a whole fifty english pounds i'll throw the other one in for free it's my BOGOF offer!
have u seen them? they are little more than a cicular saw on it's side with a fancy sole plate no way are they woth £235 but like i say i was sick of people asking for my carpet fitters to cut doors, this way i can offer the service knowing full well the customers are too tight to pay but it gets me off the hook, it's a job i can do without.
take it u like power tools. if you do buy a door cutter the ones with the spacers to adjust the hight are the better, the ones you adjust the spring have to be set pretty much spot on or they jump along the bottom of the door and chew it up a bit. I too have been looking at tools from USA and might buy a dewalt 18v drill/driver/circular and jig saw almost half the price of uk.
Mof, if you look at my previous posts on this thread, then you will see I felt the same way, till I <u>had</u> to use one. No option, the customer wanted it done this way and was willing to pay for the rental/time to get it. I learned something new and she got what she wanted.
how much do u all get for cutting a door? everyone calls carpet fitters for not cutting doors but that is because customers expect us to do it for free. if i cut 4 doors on a top landing i only chatge £30 for the lot and the customers think i'm robbing them, they think it is part of my job when fitting the carpet.
