Cutting Down the Draught Under an "External" Door
Discussion in 'Carpenters' Talk' started by DufferDIY, Dec 6, 2017.
  1. DufferDIY
    DufferDIY Member
    It has been brought to my attention that our front door is "naff" and is to be replaced. SWMBO has spoken therefore it has been added to the list.
    Existing door frame is to stay.
    Now when I say "front door", I mean the old front door. It's now the door between the unheated, draughty but water tight porch and the rest of the house. It's old school rebate-in-the-bottom-of-the-door-to-accept-raised-metal-threshold-strip type of thing, and naturally some air finds it's way around it. Strip is ~6.5mm wide and stands ~14mm high and is probably as deep again embedded in the wood.
    I've looked at some of the threshold sills like but they seem pretty obtrusive or just too high. Perhaps there are "nicer" ones on the market that I've not spotted.
    So my thoughts are to remove the bar and either replace it with rebating the new door to fit or router out a groove to take a brush seal eg Although the latter is aesthetically more pleasing to look at a smooth threshold, experience has taught me these brushes are awkward to fit accurately and will wear over time.
    But before I go for the former, I thought I'd ask if there is another, probably better, way.
  2. KIAB
    KIAB Well-Known Member
    I would cut my losses & replace the lot, with new door & frame, you would then have multi point locking,proper sealing ,etc.
    Jord86 likes this.
  3. DufferDIY
    DufferDIY Member
    Briefly considered that but that's a lot of disturbance to the decor and plasterwork. Multipoint is overkill for an internal door lol. Also triples the cost.
  4. KIAB
    The advantages with improved weather sealing,low threshold option & improved security (it is a front door) outweigh the disturbance to the decor and plasterwork.
    Jord86 likes this.
  5. DufferDIY
    DufferDIY Member
    Well to get to this front door you still have to get through the outer front door with multipoint locking lol
  6. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Maybe a better idea to draught-proof the outer?
    Mr. HandyAndy - Really
  7. KIAB
    Ah! a vestibule doorway, still wouldn't skimp on the security,
  8. DufferDIY
    DufferDIY Member
    And it would still be a wooden door in a wooden frame lol
  9. DufferDIY
    DufferDIY Member
    That's another project. Previous owners put in Upvc doors and windows in the porch that was built by the owners before them, but they skimped on the roof. Wind blows in around the edges of the roof and through the ceiling. Solution to that will be to replace the flat roof with a pitched roof.
  10. GoodwithWood
    GoodwithWood Active Member
    Cost wise I would probably fit a slimline stormguard. Other options seems to be throw a lot of money and disruption at it when all you want is a cheap and simple way of draught-proofing.
    Probably the simplest would be this:
    Regarding the roof, a good flat roof will not allow wind in so you could save money by having a "professional" flat roof installed. My preference has always been pitched as I'm old school and never been a great fan of flat roofs even though modern materials have made a huge difference compared to the roofing felts of old.
    KIAB likes this.
  11. Isitreally
    Isitreally Well-Known Member
    You could just try some self adhesive foam tape stuck to the up right bar or door, to seal the obvious gap between it and the door,
