Top quality (expensive) diamond disc in angle grinder, plus considerable practice. Do what lamello suggests
hey there, yeah it is a pretty tough job and messy, you need grinder with diamond tip blade, mark the area with masking tape makr on area needing cutting ( this avoids chipping the granite) then cut slowly to avoid any jerking and nipping of the blade i am a granite fitter so reply if you have any other questions
Piece of cake, I live in saarf affrikka,everyone has granite tops. Mark tops directly with yellow crayon.Angle grinder with good diamond blade, get your mate to fill an old washing up liquid bottle full of water and dribble onto blade while cutting. Cuts down heat,saves blade and stops flowers being granite dust reinforced. Good luck.
Piece of cake, I live in saarf affrikka,everyone has granite tops. What, even in the slums of Soweto?
You need to book yourself a holiday,the South Western Townships often put other small country's to shame nowerdays. Forget Greece,Turkey even Spain. Come to Saarrf Africa,I would be suprised if you ever wanted to leave.
