Damp first floor bay window
Discussion in 'Builders' Talk' started by Cassas00, Nov 17, 2019.
  1. Cassas00
    Cassas00 Member
    I have a patch of damp coming through my first floor bedroom bay window. It's only recently been plastered.
    Damp: https://ibb.co/T8bsyn7
    My first thought is that rain is getting past the window frame.
    From inside room: https://ibb.co/BncQCJt
    From outside: https://ibb.co/cbPD4TG
    So plan is to renew seal around window. Is there anything else I should consider. Maybe pointing?
    Cheers
  2. Bob Rathbone
    Bob Rathbone Screwfix Select
    You see that hole in the pointing just at cill level between the two windows, the rain is entering there.
  3. Cassas00
    Cassas00 Member
    Ah yea, how did I miss that. I'll get it repointed
