Deck post
Discussion in 'Landscaping and Outdoors' started by mcb199, Jul 10, 2013.
  1. mcb199
    mcb199 New Member
    I'm fitting some newel posts along with handrail and spindles around my deck. I have fitted the posts on the outside of the deck. I have used bolts and tightened them up on the inside of the frame. But they are not as solid as i would want them and they are moving when they are leant on. Is there anything I can do to stop this and reinforce them?
  2. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Put these on the bolts between the post and the joist.
    Mr. HandyAndy - Really
  3. mcb199
    mcb199 New Member
    Will they be strong enough to prevent any movement of the post? Someone suggested using a PU resin adhesive. Might just use both to be on the safe side
  4. Mr. Handyandy
    They should be strong enough. They are the sort of thing used with bolts to to joint house joists in some situations.
    For the post/posts where you have bolted through the remaining quarter, you may need a dowel up the centre of the post, down through the board and into the joist.
    I should say that your problem is that the joists are not deep enough, your bolts are too close together to stop the leverage.
  5. mcb199
    mcb199 New Member
  6. mcb199
    mcb199 New Member
    Just put up a couple of photos of the posts. The joists are 4 x 2. would it also be worth putting another section of timber on the inside of the joist and bolt though that aswell as this will add more distance so the bolt won't be as close together?
  7. surfermick
    surfermick New Member
    bolts are to close together and theyneed to be spacedcorner to corner, you have no real bracing going on there. also as Andy says use those washes between the two bits of wood, that will help.
  8. Mr. Handyandy
    That'll still leave the bolts the same distance apart. From here the bolts look like they are 30mm and 60mm up. To keep from moving, they would need to be 40mm and 140mm apart. You can't do this obviously. To stabilise them(the main full posts) you could put two 100mm screws from inside through the joist into the post.(Drill and pilot accordingly) The best place for those screws in relation to the bolts would be a 'T' position(the screws being at the outer ends of the top of the T. There is also the possibilty of adding a wide 'L' bracket to the post/joist(4 25mm screws), under the board.
    For me, I would put one star washer on bottom bolt betweem post and joist, and two 100mm screws from inside.
  9. mcb199
    mcb199 New Member
    I will give that a go. Thanks for all your help
  10. Sean_ork
    Sean_ork Screwfix Select
    you can add as many screws, serrated washers and brackets as you like but unless you provide some form of support for the top of the post - it will still move
    it needs a return building in
  11. Addison001
    Addison001 New Member
    Message was edited by: Screwfix Peter
  12. surfermick
    i think Andy's right here, 3 fixings are necassary, but myself i would use one bolt bottom centre and 2 bolts top as far apart asthe post allows.using the star washers in all 3.
  13. mcb199
    mcb199 New Member
    How would I build a return into what I've already got there?
  14. Sean_ork
    post a picture showing the extent of the railing, across the entire deck - I'd want to know what you want it to look like when it's finished
    If you've just fixed a single post (as shown) but have not yet fitted the top rails or spindles then that single post is bound to have some movement
