just wondered if the treads and riser specs for domestic stairs are ok to use with decking.cant see much probs myself but thought i'd ask?? thanks
I seem to recall a debate from before but i think they fall into the other catergory, max rise of 190mm min going of 250mm. but to be fair anything less than 42 degrees with 10 inch tread will be okay
some insurers are now asking if a property has decking round it/so called fire risk. many caravan parks won't allow wooden decking for this reason.
i recently built a deck around a caravan which was far more substancal than the van if anythings is a hazard its the van themselves. 34k for a tin hut and a few more k ground rent each year, anyone buying one of those must be mental
