Decking questions
Discussion in 'The Small Print' started by PJDeck, Oct 6, 2020.
  1. PJDeck
    PJDeck New Member
    Hi
    New to the site looking for a little advice.
    I’m building a 3.6 x 2.4m decking area for my sister in law. The decking is coming off a caravan but there is about a10-12 inch slope.
    I was planning on raising the lowest point next to the caravan on 3posts at 0,1.8m and 3.6, then let the natural slope take the high end dig out a little onto boards without fixing. Is this viable.
    Also the cost is spiralling a little are 100mm fence posts ok with exterior grade decking joists 47mm x 150mm for the sub frame and internal joists at 400mm deck boards are 2.4m x 24mm.
    Think the spacing is ok on joists, just wondered if I could use smaller not as thick joists for the internal joists. Any help/advice greatly appreciated. Would also put noggins in. Also attaching with Timberdrive 100mm screws.
    Thanks in advance attached a couple of rough drawings.
    Area under an awning using for storage and sofa.
