DeWalt DC618
Discussion in 'Tool Talk' started by jimoz, Nov 7, 2018.
  1. jimoz
    jimoz Active Member
    Had this nail gun around 5 years now. Always looked after it and has always been good to me, If not a bit heavy! Just today/yesterday started to intermittently misfire with it becoming more frequent this afternoon. I tool the top off but there was nothing obviously broken in there. Going to investigate more tomorrow I think. I found a Dewalt diagram and i'm going to look for damage to upper and lower bumper as these seem easy fixes. I am guessing both the bands are ok if it is intermittently firing. Anyone else had a similar problem and know a likely fix? I will try to attach a link to video in next post.
  2. jimoz
    jimoz Active Member
  3. jimoz
    jimoz Active Member
    Was much better today probably happened 10 times in a few hundred nails. Was almost unusable yesterday. Strange.
  4. diymostthings
    diymostthings Well-Known Member
    Needs cleaning/lubrication? Something is sticking in there...
  5. jimoz
    jimoz Active Member
    No from what I understand lubrication with these is a big no no. They work on friction or something. I know the video is poor quality but in reality i keep it quite clean and don't batter any of my tools.
  6. Job and Knock
    Job and Knock New Member
    Yes - absolutely no lube with the DW guns because they all work on friction drive. Clean off any muck inside the casing and maybe adust the tension screw - that' about it, really. I now have a DCN660 - wish I'd kept my old gun at times
  7. wiggy
    wiggy Well-Known Member
    Clean the slide where you put the pins
