Hi All, I have just purchased this item:-https://www.screwfix.com/p/dewalt-dck2510l2-gb-18v-twin-kits-2-x-3ah/2301v In the picture it shows the DCB115 charger but the actual charger supplied is a DCB113 which appears to be an inferior charger with longer charge times. Can anyone confirm what charger it should have been supplied with? One reason for purchasing this was the DCB115 charger as I already have a DCB113 charger that came with my Multi-tool.
The picture is irrelevant really, it's the written Spec which confirms exactly what you're buying, it does state a 70min multi voltage charger is part of the deal, so if that's what you have then you've not been done over. There's probably something in their clause stating pictures are for illustrative purposes only. Still, £45 off a £245 brushless twin set isn't something to be sniffed at.
Dewalt DCD796 is slightly smaller,& has more torque 70 Nm compared to 60 Nm for DCD795. https://www.powertoolworld.co.uk/dewalt-dcd796n-18v-xr-brushless-combi-drill-body-only https://www.powertoolworld.co.uk/dewalt-dcd795n-xr-combi-drill-18v-body-only-brushless
