Dewalt leg stand
tore81
Screwfix Select
2379EA84-E0C7-4A1F-9BE8-F13E384EB2E6.jpeg Hi all, looking at putting my Bosch mitre saw on to the dewalt having a few issues anyone has anyone had this problem?
the feet on the saw seem to be in the way and I’m wandaring if I’m mounting it correctly.
Please see pics
View attachment 85028 Hi all, looking at putting my Bosch mitre saw on to the dewalt having a few issues anyone has anyone had this problem?
Please see pics
The only thing I can think off is to remove exsisting feet off mitre saw
do it the other way round as in handles to the back
just make sure the fence and bed line up over the beam off the leg stand
this allows easy removal from the stand as in stand at the front hands to the back grab handles to release and tip saw up towards you
Mount the brackets onto a piece of 3/4” ply and use that as a table, put the saw on that.
that would work for lighter work with a smaller saw
but iff you are cutting say 6x2" on a 8x1/4"[216mm]plus saw it needs to be fairly accurately over the beam as even a few inches back or forth can upset the Ballance and by being clipped to the stand it locates it positively
also by locking in to the stand the length stop on the arms or beam remain accurate
I have the same DeWalt support, the saw needs to be attached to the mounts to work efficiently and accurately.
Not to come across funny or anything but I don’t understand what either of you are saying, I’ve mounted a 216mm Bosch saw on top of an 18mm top, with the brackets bolted to the ply which obviously clip onto the saw stand, used that setup for years without issue and still do occasionally, though now I have a 305mm Makita saw which again sits on the ply top, the only difference being I raise the saw stand supports higher to accommodate the deeper bed on the saw. It’s rock solid.
its more the security point when dealing with heavy timber and even carefully placing on a saw the tendency is to firmly push fully on the fence will cause between a small fraction off a movement to to a gradual bit off movement getting greater with use which can stop the length from the stop changing
as i said above a board is great and i use one my self its more the accuracy and noticing the saw creeping off the middle off the board but as you say a board work fine and agree with that its just personal choice :D
i found with the dewalt 18v 365 because its ultra light it can try and tip on a board where as clipped on it wont
You can screw the saw base to the ply if you so wished :)
Back
Top
