Doz Stanford
New Member
Greetings,
Over the past few years I have been working to insulate a mid terrace house built in the 1860's and I have reached the point I need to start installing some condensation vents.
I have opted to go with the insulated 75mm Passyfier vents which require a 152mm hole.
The walls are double skinned Luton bricks, no cavity and some of the walls I'll be drilling are rendered outside, some are not.
I have never drilled out such a hole, although a neighbor that is a retried electrician that has drilled a few tumble drier vents has thankfully offered to supervise my first attempt.
The advice I need from the good folks of the Screwfix community, is exactly what to buy. I have watched some Youtube videos, read a few posts on this forum and spoken to my neighbor, and have come up with the following list to purchase...
Drill = Bosch Professional GSB 162-2 RE
To make Pilot hole all way through = Bosch 2609255436 400mm Masonry Drill Bit with Diameter 8mm
Core Bit Adapter = Bosch 2608580865 Adapter for Diamond Drill Bit, Black, 1/2-Inch - 240 mm
Core pilot bit = Bosch Professional 2608597921 PILOT DRILL BIT FOR DIAMOND DRILLS
Core Bit = Bosch 2608587333 Diamond dry core cutter G 1/2" (152mm)
Is this everything I need ?
Have I chosen the right adapter/pilot for the core bit ?
Renting a drill is not an option, I need in total 5-8 holes and I'll be doing them over a period of time, not all in one go so it would require renting the drill 4 or 5 times.
Many thanks for any and all advice and comments in advance.
A
A
