Hi all,
I asked on this forums recently about problems with my (LED) lights which are flickering. So far I was unable to figure out what the problem might be, so I thought I'd consider replacing the bulbs as well as the switches - and wanted to ask for your recommendations on LED bulbs (E14) and switches.
Requirements:
The setup needs to be dimmable (either dimmer switches and dimmable bulbs or smart bulbs)
I'd like filament bulbs - they look nice and some of the bulbs I have are exposed / visible
Preferably smart switches and glass switches (I think they're not so common so am happy to hear your thoughts if you believe they're not very good)
The switches need to require no neutral wire as my building doesn't have it apparently
The set up should not be terribly expensive as I need around 31 bulbs and 4 switches (one of them 3 gang, the others 1 gang)
Am keen to read your thoughts and recommendations on what you think is good and what you'd recommend I avoid (brands / manufacturers etc).
Thanks
Requirements:
Thanks
