Dimmable LED buzzes after 30 minutes
Discussion in 'Electricians' Talk' started by JimP, Nov 18, 2020.
  1. JimP
    JimP Member
    I have a dimmable LED that begins to buzz after about 30 minutes of being on, is this simply because it has warmed up or something wrong?
    Can anyone recommend a solution or a good quality bulb that doesn't buzz?
  2. Teki
    Teki Screwfix Select
    Which LED lamp and dimmer are you using?
  3. JimP
    JimP Member
  4. Madeofale
    Madeofale Active Member
    does it buzz on full or only when its being dimmed, if when its dimmed does it stop when you turn it up to full
  5. JimP
    JimP Member
    Only when dimmed and yes turning it up to full stops the buzz
  6. Teki
    I'm not really a fan of Luceco LEDs. They aren't very reliable.
    Try something like a Philips or Megaman lamp.
  7. JimP
    JimP Member
    Thanks I'll do that. That fact it's quiet to begin with suggests the LED is the culprit
  8. Teki
    Yes, if kept at the same dimming setting something inside the lamp is getting hot (possibly a coil) and it starts to buzz.
    JimP likes this.
  9. Bazza
    Bazza Screwfix Select
    Where are you getting the neutral from for your switch?
  10. JimP
    JimP Member
    It comes down from the ceiling rose back to the switch.
  11. Bazza
    So you have a live, a switched live, a neutral and an earth to the switch?
  12. JimP
    JimP Member
    Yes I do. I was surprised the neutral was there, my house is a relatively new build.
