Dimmer Switch
Discussion in 'Electricians' Talk' started by Peter Gee, Apr 5, 2021.
  1. Peter Gee
    Peter Gee Member
  2. Teki
    Teki Screwfix Select
    Find a cheap dimmer switch that has the right frame colour and swap out the internals for the Varilight one that you have. Or just wait until the paint on the wall fades ;)
    sparky steve and Bazza like this.
  3. Peter Gee
    Peter Gee Member
    mm, that sound like a good idea. Is it relatively straight forward to do? I don't want to break the £25.00 dimmer I've just bought! I don't suppose it would work with the old switch? :)
  4. DIYDave.
    DIYDave. Screwfix Select
    It really is a 2-3 minute job
    Pull off plastic knob
    This will reveal a slim nut that holds switch module to faceplate
    Spanner or pliers to undo nut, it won’t be super tight
    Swap over faceplate
    Add nut and tighten - take care not to scratch faceplate with pliers / spanner
    Repkace knob - will have a flat section inside that lines up with flat on switch module spindle
    Job done
    Good luck
  5. Peter Gee
    Peter Gee Member
  6. Bazza
    Bazza Screwfix Select
    The type of dimmer depends on the type of load. A dimmerable LED will need an LED dimmer.
    A 60watt halogen lamp needs a different sort of dimmer.
  7. sparky steve
    sparky steve Screwfix Select
    Or he could just simply dim the lights?:D
    Rulland likes this.
  8. Peter Gee
    Peter Gee Member
    I've already go the dimmer switch, it's just that I don't like the shade of white, somebody suggested that I change the dimmer faceplate. I just wanted to know does the replacement faceplate need to be an LED Dimmer faceplate, or will any dimmable faceplate do (i.e. not LED)?? :)
    Cheers
  9. Bazza
    It is just the dimmer module that is specific to LED. The faceplate doesn’t care what you have on your ceiling.
  10. Peter Gee
    Peter Gee Member
    Ok, so would the old "switch" face plate do?
  11. Bazza
    I have no idea. If it’s a bit of plastic with the right sized holes in it then it will probably suit.
    But you have the advantage of being able to see the old switch plate, I can’t see it from here and, unfortunately, clairvoyance isn’t one of my powers.
    sparky steve likes this.
  12. Peter Gee
    Peter Gee Member
    Lol, ok, thanks for your input.:)
  13. Comlec
    Comlec Screwfix Select
    That wouldn't help, it is the power of 'remote viewing' that you need. Amazon even sell book on the subject and other such nonsense
  14. sparky steve
    You need one of these in your toolkit Bazza:D
