Hi, Wondering if any appliance engineers that can help.. Zanussi dishwasher has standing water inside and lights are lit, can't make out an error code either, pressing buttons just makes them all flash. Have removed pipes etc and no kinks or obvious blockages Any Ideas?
If standing water inside, then suspect a pump issue,wash pump blocked,siezed, anti flood device activated,etc.
Thank you, nothing simple then..? It's about 11 years old I think so suspect it may be a new one instead of a repair job
Or it might be a blown circuit board (happened to me once). Dishwashers are relatively simple machines and the fault will have a simple answer. Get a repairer to have a look and they'll fix it in a few minutes... then spend an hour watching it go through a cycle! Edit to add : This place would be a good start https://www.google.co.uk/search?q=z...MBsAKHakLCuwQrQIoBDAFegQICBAI&biw=320&bih=454
Try tipping it over onto one side, right over that is.if the floats stuck it should cure it. Get ready to mop the water up though.
