Dishwasher not draining!
Discussion in 'Plumbers' Talk' started by leechy, Jan 10, 2007.
  1. leechy
    leechy New Member
    Just fitted an intergrted Bosch dishwasher for a friend, its fitted directly next to the sink cupboard. The drainage hose is fed down to floor level, uder the cupboard where it enters under the sink. It comes up and is connected to the P trap on the sink via an appliance nosel.
    The problem is that after a cycle it does not drain properly and there is water in the bottom of the machine up to the bottom of the door. Annoying when you open it and water leaks onto the floor.
    I should mention thats its a second hand machine with no instructions. Is it not draining because of the routing of the waste pipe? Any ideas?
  2. Virtual Voodoo
    Virtual Voodoo New Member
    The person you bought it off was getting rid of it because it had a faulty drain pump! :^O
  3. tomplum
    tomplum Active Member
    some d/washers don't have a pump and rely on gravity, if so you will need to plumb the drain at ground level.
  4. PDPS
    PDPS New Member
    level.
    If you can find a model number this page should help.
  5. Tricky Dicky
    Tricky Dicky Active Member
    Hi
    I've got a Bosch D/W, so hopefully will be useful:
    Is the filter clean, mine is below the bottom sprayer bar, just lift out and clean.
    I also had a flood, and this was due to gunged pipes. After removing the side panels, a kettle of boiling hot water, (take care), a babies bottle brush and some Mr Muscle cleaner or similar cleaned the pipes and got the machine back to working order.
    I ran the machine without the panels, whilst I studied the flow of water thr' the pipes, many were transparent, if was a work of art seeing the flow, siphons working etc, and could deduce the blocked pipe.
    Best of luck
    Regards
  6. Garfield
    Garfield Member
    Before you start taking the machine to pieces,check the little spigot on the trap under the sink that the outlet hose connects onto,it may have a blank on the end that the hose connects to,or at the point where the little spigot joins the main part of the trap.
  7. Planet Niton
    Planet Niton Member
    You could get the manual for installation & advice on height of drain etc on Bosch website (or call them about it)
    https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
    Good luck!
  8. leechy
    leechy New Member
    Turned out to be a blockage in the drainage hose!!
    Thanks again for all the advise!
