Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Where to put it though? I'm also not convinced having it on the right is great either as would have to have a standpipe with waste running behind the back to the stack on the left, but I'm a bit stumped where to put the washing machine.
you don’t need to have a ‘local’ stand pipe, just extend outlet hose, although there is often not much room between the back of an oven and the wall, so would have to route low level. For what it is, and aesthetically, it would look better on the right, or go integrated with a door.
just nit picking
I’m tired and had a glass or 2, I’m sure someone will come up with a light bulb moment
Put washing machine where drainer currently is, move sink unit unit to right of where it is, and turn sink round so draining board is on the right.
Does that work.
Advantages are
No doubt I've overlooked something!
- drainer is in "awkward" corner
- plumbing for sink and washer are near each other
- easier to get washing machine in/out for maintainence
Good luck,
Regards,
Cando
Change to a R/H drainer and fit the washing machine next to the door, although an inset drainer won't interfere with the washing machine. What about an integral washing m/c if kept the same layout next to the sink, can you get a 600 cupboard in if you altered the base unit sizes.
