DIY Pergola!!!
Discussion in 'Carpenters' Talk' started by Lianne, May 14, 2020.
Tags:
  1. Lianne
    Lianne New Member
    I am attempting to build a pergola but I am concerned about which fixings to use. One side will be attached to the garden wall and the other side will have posts.
    I am using a 2" x 6" x 4m piece of timber which will have additional weight from the joists which are also 2" x 6".
    What fixings would be recommended going into a part brick (original Victorian red brick) / part breeze block wall.
    As no posts on the wall side I am scared of it falling.
    Thanks,
    Lianne
  2. Rodney Green
    Rodney Green New Member
    A picture would be useful. However, I’d consider hanging the joists from the wall individually with metal joist hangers. It’s a bit more work but will be easier to fix securely than a huge piece of thick timber. Then run the joists to a lateral timber joist supported vertically by your posts.
  3. WillyEckerslike
    Google thunderbolts or masonry screws/bolts. They will offer a nice neat solution to fix your beam to the wall. Easy to use as well. Good luck.
    Lianne and Astramax like this.
  4. Astramax
    Astramax Super Member
    As above also known as concrete bolts.
    Lianne and WillyEckerslike like this.
  5. Lianne
    Lianne New Member
    Thank you.
