DIY roof retile
Discussion in 'Builders' Talk' started by Mowbs, Mar 22, 2017.
  1. Mowbs
    Mowbs New Member
    Hello
    After being quoted £18k a couple of years ago to retile my roof I have decided to do it myself.
    I have done loads of research and I'm pretty sure I know what to do although I'm also very aware of the potential of giving myself problems in years to come if I don't get it right.
    It's a 'T' shaped bungalow with a pretty large footprint so has 4 valleys and 4 gable ends. I'm in Scotland so I plan to use 11mm OSB as sarking then membrane and a smooth concrete tile.
    I just have a couple of questions that I can't seem to find answers to on the internet.
    Battens: since I'm using 11mm OSB as sarking and won't have gaps between them, should I use counter battens? I'm thinking any water that gets between the tiles will get trapped by the horizontal battens if I don't use vertical ones.
    How often are the battens nailed, I obviously don't want to make any more holes in the membrane than I really have to.
    Do I just use galvanised nails, do people ever use stainless steel nails? Would there be any benefit in using copper nails?
    Membrane/felt: What kind of membrane would anyone recommend? I don't mind spending a little more for good quality since I'm saving money doing it myself but I have also read people saying felt is better than modern equivalents.
    My roof currently has asbestos looking small plates under the overhanging tiles on the gable ends. I plan on using plastic dry verges. Do I just tuck the membrane under the OSB and nail it underneath cutting it back close to the brickwork which would be hidden with the dry verge? If this is the case, should I buy and measure the dry verge first to ensure I don't overhang my OSB sarking by too much which would leave visible membrane from below.
    Where the membrane meets the gutters, is this left a couple of inches longer than the OSB rather than folded back and nailed from below and hidden by the guttering.
    The membranes tend to be bright colours like green or blue and anything left on show is going to stand out.
    Thanks in advance for any replies, I really appreciate the input from anyone with expertise in this area.
  2. chippie244
    chippie244 Super Member
    Get a roofer in, you are well out of your depth.
    CGN and KIAB like this.
  3. KIAB
    KIAB Super Member
    Get 3 or 4 quotes for the job,definitely not a job for a beginner.
    CGN likes this.
  4. CGN
    CGN Screwfix Select
    Thirded:D
  5. Mowbs
    Mowbs New Member
    I appreciate your concern but my question wasn't whether or not you think I'm up to the job.
  6. chippie244
    We don't think you're up to the job and I for one wont be helping you cock your house up.
  7. sospan
    sospan Screwfix Select
    I guess the incentive for doing this yourself is to save money ? With all building jobs the price quoted is going to be a mixture of materials and labour.
    The materials you can source yourself and with a lot of shopping around you could probably get close to if not better than "trade" prices.
    With the labour costs you can split the costs between the jobs you can do and know how to do and those that will require more skills. If you can find a reliable roofer, then there is no reason why you couldn't strip the roof, board it and do all the prep work and get the roofer finish it.
    This way the costs should be a lot less
    Mowbs likes this.
  8. chippie244
    You've got to be quick enough to go from stripping the old roof down to getting the membrane on before the weather changes though otherwise you've got a very wet house.
  9. Mowbs
    Mowbs New Member
    Gee, thanks for that chippie, I hadn't thought of that.
    Doall likes this.
  10. chippie244
    You are asking some very basic questions.
  11. sospan
    There's a house near me, where the roofers have put on new slates but have left it for the last two weeks with three rows of slates and the ridge missing
  12. Mowbs
    Mowbs New Member
    The roof is watertight with the membrane on.
    Chippy, you already said you won't be helping me 'cock my house up' so why bother filling my thread up with your posts?
  13. chippie244
    Another know it all newbie :):)
  14. Mowbs
    Mowbs New Member
    Chippy. I don't know what your problem is but please go away. You have an immensely annoying face and attitude, I've looked at some of your other posts and they all have a similar theme running through them. Unhelpful and trying oh so hard to be funny.
    I suggest you stay off the internet when you're drinking.
    KIAB likes this.
  15. chippie244
    Good look :)
  16. sospan
    Aww, a lot of people of people think Chipps looks cute :D
    KIAB likes this.
  17. chippie244
    I preferred his opinion :p:p
    KIAB likes this.
  18. sospan
    When I read the first sentence, I thought it was the ghost of HA's past ;)
  19. chippie244
    For heaven's sake :rolleyes::rolleyes:
  20. chippie244
    Ooh, check him out... :p:p
    KIAB and CGN like this.
