Hi I am looking to furnish a room that is relatively small. I have had a look at the desks sold by IKEA and think they are relatively expensive for what they are. My plan is to get a couple of storage drawers from IKEA and then create my own desktop from an offcut of some sturdy plywood. Then put this on top of the storage drawers in order to create a cost effective desk. I plan to manipulate the height of the desktop so it sits over the top of the radiator and below the edge of the window board. The radiator is directly below the window looking out of the room. In order to manipulate the height of the desktop, is my best bet to use pieces of the same height wood to manipulate the height ? Any advice appreciated. Is my first attempt at trying to do some bespoke carpentry. Have chosen a task that should be relatively simple I hope. Cheers IM
Using kitchen base units to support desk here, 500mm drawer unit one end & two 500mm base units other end & knocked up 6x1 pse frame for them to sit on.
So many ways to achieve this, depends on how much you need to raise desk top by; Batten tops of drawer units, sit ply on top, small angle brackets to secure top to batten Is the height between top and drawers enough to be usable space ? If so, just batten 3 edges of drawers, leaving front open for storage (if usable gap) If a greater height than readily available battens, just cut strips from 18mm MDF to height, secure with brackets as above What will you be finishing the ply top with ? Untreated will soon get grubby
Was thinking the same thing. Ply is really not the best of things to use for a Desktop. I would go for 18mm or 22mm MDF. Can then be painted to match the storage draws, or a contrasting colour to the draws to match another colour in the room.
Agreed. It's difficult to get a smooth and comfortable edge on the ply which will chafe on your arms as you work.
Thanks for the above advice. I will get some mdf and paint that. I will then prime and paint it. I don't think the gap will be usable space.
If using the desk as say a home office with a pc and keyboard, need to consider what paint finish to use on desk carefully It’s amazing how much damage and wear a keyboard can inflict on the surface over a couple of years just by moving around during use Make sure items on desk have felt/rubber feet to minimise damage and wear marks I would think either an eggshell finish or look at Bedec Multi Surface Paint - it’s very nice and hardwearing. After priming and undercoating the MDF (I like the combined acrylic stuff by Leyland), 2 coats, rub down lightly between each coat P180, then the Bedec Use a 4” foam roller for all coats, roll fairly slowly to avoid air bubbles, you should get a finish that looks like it’s been powder coated - almost totally flat, just a tiny even texture to it Also that raw front edge of MDF needs some extra attention to get it looking good once painted. Either ‘lip’ it or loads info on previous posts about this subject PS. Don’t know span of desk top but I would also batten wall between drawer units for additional fixings and support Post some pics when done
my thoughts if enough room am offcut off worktop from the bxq offcut bin cut to size you need at least an inch above a radiator to allow the heat to escape from the back off the radiator iff the radiator is fully within the knee well you will loose a lot off heat output if there are thermostatic valves they will shut down when the valve is warm not the room
